Xenon retrofit with Hella projectors and LED position lights
Hello all, before, my headlights have H7 kit with much glare
Purchased Hella 50 mm H7 halogen projectors (95 eur/each) from Tm Tuning because I want to use H7 xenon kit with them.
I couldn't disassembled projector's lens and reflector parts.
New ECE headlights, H7+H7
Workin on it :
H7 rebased 4100K (from autolamps-online):
Custom made base :
Painted projectors :
Don't want to cut back of reflector ...
Left headlight was retrofitted first , for test ...
Left : halogen FF reflector with H7 kit, right : halogen DE projector with H7 kit :
Cut-off and pattern of hella halogen DE module only (with kit)
Light distribution is very wide, and there ise a yellow line on the center of cut-off
I must calibrate up-down level of new headlights, I think no need for right-left level.
Need suggestions-opinions, thank you !
Workin on it :
Custom made base :
What an incredible amount of work!
Well done
I always wondered what made the beam pattern and it is the metal plate in front of the lens!
The pictures with the projectors switched on look great.
Well done
I think you have been very clever to develop this idea, for many of us it would seem a bit risky (we have funny vehicle testing laws about headlights).
We would have to buy the projectors and ballasts and some new spare headlights to use for the project, which may or may not work out so well done for trying it out, I hope you are pleased with the lights.
No, it's my friend Ilke's car. http://www.cardomain.com/ride/431153slick wrote:I think it was on some site which shows your crs, I remember your blue 406 - exec model?
Update :
I replaced old H7 projectors with D2S xenon projectors. With these projectors, I got more sharpest and purplest cut-off line, much wider and powerful light distribution.
I cut back of low beam reflector because these D2S projectors are 2 cm. long more then old ones.
Each of LED in stripe have 8000K color temperature, 120º angle, 120mA and 3 lumen output. This stripe is flexible and have many different color options.
I cancelled position bulbs and retrofitted a piece of LED stripe in headlight housing. I cut the stripe into 6 pieces (which has 3xLed) and used one of them.
Position lights ON
Position and low beams are ON
Position lights ON
Re: Xenon retrofit with Hella projectors and LED position lights
any ideas where can i find this led stripe????
