MFD and radio stays on
sonicspanner
Post by sonicspanner »
Hi can anyone help, my mfd and stereo stay on, the stereo can be turned of manually, but the MFD stays on pemantantly, its also a bit dim, but guess thats because a bulb has blown, also the outside air temp just shows 2 dash's, guess the sensor has packed up, but it happened at the same time as the mfd wouldn't turn off with ignition, any ideas or is it a replacment mfd, its bloody annoying!!!!!! :shock:
Re: MFD and radio stays on
is this a d8 or d9
nutski
Post by nutski »
I had this on my D9, not too often though. Only started happening after i fitted my connects2 stalk adapter for my Sony HU.
Never found a permanent cure but used to just unplug the MFD then plug it in next time im in the car, would sort it for weeks or months at a time!
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
It's probably something shorting the permanent live to the ignition-switched live. I'm guessing it's a D8 and you can also switch on the headlamps without the key, and the brake lights work without the key either... Usually this would be caused by a dodgy ignition barrel.
maxxymilian
Post by maxxymilian »
Have you fitted an aftermarket alarm system or anything else?
sonicspanner
Its a D9 model, 99 T plate hdi. The only thing i've fitted is a parrot hands free kit, witch also stays on, but the power is fed from the sterio permanent feed, even with the hands free kit unplugged it has no effect. :?:
