Got Airbag Fault codes home
Ive finally got round to taking the car to hobson electronics the people who have a diagnostic reader near me, but anyhow he reset the light but it come back on because it was a permanent fault, and they dont know how to fix things so i got the man just to print the list of fault codes related to the airbag. Otherwise the car got a clean bill of health although the machine picked up voltage spike on the bsi from the time it went mad. Anyhow heres the codes:
Total Codes: 004
CODE001:
A06 right side belt permeant module ignition fault - short circuit
CODE002:
A06 left side belt permanent module ignition fault - short circuit
CODE003:
[1e,ed,a,8], permanent please refer to fault relevant technical manual
CODE004:
P0A07 Front left side permanent module ignition fault - short circuit
so then whats all this mean the third code he didnt understand at all, but with these codes what do i have to check next?
forgot to add this bit at the top of the printed reciept:
X431 DIAG Report LAUNCH
SMARTBOX: 980249172900
Total Codes: 004
CODE001:
CODE002:
CODE003:
CODE004:
Re: Got Airbag Fault codes home
In particular what does [1e,ed,a,8] mean?
anyone got a fault code list?
I've got no idea about the codes, I had a quick google but all I found was a talking horse. You know what I think though...
406executiveHDI wrote:Ive finally got round to taking the car to hobson electronics the people who have a diagnostic reader near me, but anyhow he reset the light but it come back on because it was a permanent fault, and they dont know how to fix things so i got the man just to print the list of fault codes related to the airbag. Otherwise the car got a clean bill of health although the machine picked up voltage spike on the bsi from the time it went mad. Anyhow heres the codes:
Total Codes: 004
CODE001:
CODE002:
CODE003:
CODE004:
406executiveHDI wrote:...i just soldered the two wires together on the input side, and soldered them to the wire on the other side.
ahy well thats that to look at something to do on saturday, but whats the mystery code about?
Bob knows, engine ECUs regularly throw out spurious codes so it could be nothing. Or it could be your original fault
who is it on this forum with the big book of fault codes?
Possibly Lord Jasper of Bluddy Clever.
dont know him too well, are you taking the micky. Im going to email peugeot uk the code see if it brings up anything.
- lozz
dont know if this will help but worth a read,
clicky linky http://www.pikit.co.uk/peugeotmt/psa%20 ... codes.html
theres lists of fault codes on there,
- lozz
icarnt find a fault code 003 listed are you sure its not 0003 ?
and 0003 is listed as : 0003 VCV (Voltage Control Valve) output actuator / sid801 hdi- Flow regulator
the car brought up a total of 4 fault codes and i just think the 003, 002 etc was just the order of the codes
is there a wire coming from the airbag ecu which sends this signal, would it perhaps be possible to stop this signal by cutting a wire which is sending the fault signal or would that cause another fault signal
PROBLEM SOLVED:
Took all the wires apart and re did them with terminal blocks, took the steering wheel centre out and while at it took out the cruise control stalk and put it back in with a post it note on both sides keeping it in place firmly, put the battery back in and hey presto the airbag light has left and went to a better place, the cruise control worked after this, too early to say if the crusie has been fixed but the stalk is in tight.
