need some help!
trying to replace my old 406 hdi 110 and every time I test drive another 406 its no where near as quick, I understand the change in ecu's from hard wired to sensor type after 2001, my question is to get a 406 as the old one is it possible to fit the ecu from a 407 136bhp 2.0 hdi ? to a 02/03 406. hope u can help really like the 406 but need the same or better performance without getting a 2.2.
any info ?
ecu change?
- 2.2 16v
Re: ecu change?
No, is the short answer. The ecu won't transfer & work, besides the power increase in the 407 is due to it being the later spec HDi - 16V, higher boost & injection pressures and it will have a DPF.
If your 110 is significantly quicker than newer models, perhaps it's been remapped? You can always get this done with a later car.
