water ??? 406
water ??? 406
hi i have a lot of misinformation, mostly low battery, but the others are also sometimes. 2 times, all 4 headlight bulbs blown, I think it's moisture as it is worst in the rain, the plug under the carpet is quite dry, hoping for help. Jørgen (Denmark)
Re: water ??? 406
Hi Jørgen, welcome
I suppose the biggest concern is that these two issues are related - the alternator is producing too much voltage and this has blown the headlight bulbs. If this only occurs sometimes you could drive with a multimeter in your car to check this but I worry that this voltage could blow more expensive parts of your car.
I know that my car does not have a cover beneath the engine and water from the road is thrown up into the area of the alternator (and power steering pump etc.), perhaps your alternator voltage regulator is not waterproof.
You say that you sometimes have other misinformation, what are these?
Re: water ??? 406
hello the other periodic error, temperature, oil, abs, and the light in the instruments disappear, thanks jørgen
Re: water ??? 406
I'm not sure if that will be loose connections or something more serious, what is the year of production for your car?
Re: water ??? 406
So *probably* multiplex. 406s have a lot of issues with bad connections with the circuit board but, with the other problems, I'd be very concerned about the voltage situation, low voltages will give all sorts of errors but high voltages I don't know about. Do these errors(temperature, oil etc.) appear on the display above the radio?
Re: water ??? 406
The voltage issue could be caused by the alternator, but them symptoms sound very similar to the problems i had when the bsi went skewe whiffe in my car, have you added any things onto the electrical system that could be drawing too much from the bsi
Re: water ??? 406
there is no extra equipment in vehicle
Re: water ??? 406
hello and thank you for your help, it was the alternator, and an error by wires to the Power steering pump. Jørgen
Re: water ??? 406
That's splendid news, I'm glad to hear you got it fixed
