is there any way of making both the tail lights work with the brakes
i know both bulbs are exactly the same bulb but only the outside one lights brighter when you brake
Brake/Tail Lights
Brake/Tail Lights
Re: Brake/Tail Lights
what do you mean by only the outside one being brighter? I recall my da noticing the left brakelight was dimmer, the issue was the bulb was on the way out, i turned it and it just broke away from its metal holder so a good new bulb could be the solution
- HimBigChief
Loop an extra wire in the bulb holder?
i mean theres 4 bulbs that are used for taillights and only the outside 2 work as the brake light406executiveHDI wrote:what do you mean by only the outside one being brighter? I recall my da noticing the left brakelight was dimmer, the issue was the bulb was on the way out, i turned it and it just broke away from its metal holder so a good new bulb could be the solution
i want to make it so all 4 bulbs work as tail lights and brake lights,
if you put your tail lights on and press brakes you will see only the outside 2 go brighter ,
i was thinking that but if you look inside were bulb (only tail light) sits you will see theres only 1 contact inside , i take it the other contact is for the brakes,HimBigChief wrote:Loop an extra wire in the bulb holder?
think i'll pass on this idea lol
