Ignition switch question
Woody
Post by Woody »
Hi folks,
I have a customer who has asked me for the ignition switch and barrel to buy. I was under the impression that the ignition switch was calibrated to the ecu. Is this correct? Would the ignition switch itself be any good to the buyer without the ecu or would he need the whole kit and cabudle?
Thanks John.
Re: Ignition switch question
could be a task for the dealer to do some computer work, or someone with a pp2000
Woody
Post by Woody »
Thanks for the reply, this ignition switch came from a 51 reg car, so has the later indicater stalks.
All the very best John.
Unless it's being changed because the original key was lost all you need to do is put the remote control gubbins and the transponder chip from the old key into the new.
Woody
Post by Woody »
Excellant! Thanks for that Steve
towbar
Post by towbar »
Mine works strangely as well. The 1st key turn/click centre powers up the radio/CD ,the centre panel lights up and shows it's status. The 2nd Click/Turn triggers a faint high pitched whine (fuel pump) ? but nothing is illuminated on the main dash. The 3rd turn cranks the starter motor, all the dash lights and warnings come on and stay lit until the engine fires,at which point they go out or change to normal running mode, Trip etc all work as they should. Lock barrel faulty ???? All suggestions welcomed.
anyone notice how the courtesy light knows the key has been removed and comes back on again, now that is nifty.
