Windscreen washers
helmik
Windscreen washers
Post by helmik »
Is there a seperate fuse for these on a 51 reg 406 HDI please? Stopped working in the freezing weather, checked them today and theres nothing when i try, not still frozen as the motor is not running.
Also looking for a wiring diagram for the radio, put in a new head unit but it wont switch on or off with the key, only on the button on the radio. Had to swap the switched and permanent lives to get it to retain setings in its memory, wont dim when i turn the lights on either so just need to know which wire is which at the wiring block. The switched live now stays live for about 2 minutes aftertaking the key out.
cheers
Mick.
406 2.0 HDI D9 in Red 2001.
Volvo C30 1.6 2007(its the wifes).
Renault Clio 197 Cup. 2.0 2008 My Weekend Toy and plaything.
helmik
Re: Windscreen washers
Post by helmik »
Must do a search first, Must do a search first, Must do a search first, Must do a search first, Must do a search first!!
Solved the windscreen washers, mini 10 amp fuse in the engine bay fusebox, which i found after posting because i didnt bother to do a search first as i am christmas plonker!!
Still after the stereo wiring diagram though.
Mick
406Iain
Post by 406Iain »
Mine popped the small blade fuse in the engine bay fuse box too.
407 GT multimedia :D
as did mine and it worked after replacing it.
