good day all,
so i have a question.
If i change the module for the keys that is situated under the areal and buy 2 plip keys is it just a matter of changing the existing with the new one?
PEUGEOT 406 DOOR PLIPS AND RECEIVER
- Scotty
- 1.6 8v
If you're talking about a D8 RF then it will work, as long as they all came from the same car to start off with.
I know as I have done just that, although it was only one plip I changed. The actual key can be removed from your orginal plip and put into the new one(s).
If you find that the automatic immobiliser unlocking doesn't work, carefully check the loom leaving the keypad for broken wires.
D8
1.9 DTLX
1.9 DTLX
