fuse help
omega
fuse help
Post by omega »
anyone no which fuse is for the windscreen washer pump on a d8? as my little handbook doesnt list it (or i cant see it :x ] cheers
Re: fuse help
nigel my haynes only lists a fuse for the headlight washer
is the windscreen run off the same pump. i would think it is
anyway if it is its fuse 5 - 10amp
Re: fuse help
BF00 - 30 Fuse Box (In passenger compartment
Fuses
Rating
Supply
Application
F1
10A
Acc +
Cig. lighter
F1 A
Batt +ve
Cig. lighter
F2
15A
Ign. +ve
Engine coolant level sensor, water in fuel sensor, instrument panel warning lamps, trip computer, vehicle speed interface module
F3
15A
ABS control unit
F4
10A
Sidelamps +
Front left side light, right tail light.
F5
15A
Low beam +
Head lamp height corrector, headlamp wash pump relay coil, low beam warning lamp.
F6
Free
F7
20A
Batt + ve
Caravan socket
F8
Shunt
F9
5A
Side lamps+
Front right side light, left tail light
F10
30A
Batt + ve
Control unit for memory seats and mirrors
F11
One touch window control unit
F12
10A
Ign. + ve
Oil breather re-heat resistor, reversing lamps, A/C engine coolant temperature unit
F13
20A
Batt +
Electrically controlled passenger's seat.
F14
Electrically controlled driver's seat
F15
Alarm control unit, radio telephone, fan relay, engine temp. control unit, control unit for memory seat and mirrors
F16
20A
Batt +
Radio
F16 A
Acc +
Radio
F17
Free
F18
10A
Low beam
Rear fog lights
F19
Side lamps
Illumination: Instrument panel, switches
F20
30A
Low beam+
Left low beam
F21
+ ign. off
Compressor cut-off relay, air conditioning compressor, pressostat, fan relay, heating/ventilation controls
F22
Acc +
Rear wiper and rear wiper timer.
F23
10A
Low beam
Right low beam
F24
30A
Acc +
Windscreen wiper, wiper timer, rear screen heater time switch relay, wiper control
F25
5A
Batt +ve
Radio memory, compact disc player, analogue clock, instrument panel, trip computer, coded anti-start, front and rear courtesy lights
F26
30A
Hazard warning
F27
One touch electric window
F28
15A
Acc +
Trip computer, load warning lamp, rear view mirror control, one touch electric window, ECU for memory seat and mirrors, high frequency receiver for central locking, front window lift and sun roof relay, stop lamps, digital clock
F29
30A
Batt +ve
Front window lift and sun roof relay
F30
15A
Acc +
Front and rear courtesy lamp, vanity mirror, glove box light, "lights on buzer" relay, overspeeding buzzer, radio telephone transmitter-receiver.
BF01 - Fuse Box (Under Bonnet)
Fuses
Rating
Supply
Application
F1
5A/7.5A
Batt + ve
Injection control unit (petrol and diesel)
F2
Free
F3
25A
Acc +
ABS and traction control
F4
20A
Batt + ve
Engine running
F5
7.5A
Relay XUD11ATE
F6
Batt + ve
Free
F7
15A
Head light wash timer
F8
Free
F9
10A
Acc +
Oxygen sensor
F10
Fuel pump
F11
Free
F12
10A
+ after relay
2665
Left front foglamp
F13
Right front foglamp
F14
+ ve after
switch 002
Left head light
F15
Right head light
BMF2 - MAXI (Fuse box under bonnet)
Fuses
Rating
Supply
Application
MF1
50
Batt +ve
Steering lock
MF2
Steering lock, + after ignition switched off
MF3
Supply 30 fuse box
MF4
Lighting and signalling switch, + relay horns
MF5
ABS/traction control
MF6
20
1-Fan Unit
MF6
40
MF7
20
1-Fan Unit
MF7
40A
MF8
Heated rear screen
Re: fuse help
nigel it also lists headlight washer in the engine bay fusebox.
fuse7 - 15amps
omega
Re: fuse help
Post by omega »
yep found fuse for headlight washes gary,[just didnt think it would be the same] hadnt checked under the bonnet will have another play tomorrow
thanks
Re: fuse help
it may not be same pump but i reckan it is
not 100% tho
