Footwell wiring connector
I pulled away the carpet in the car im breaking to find no multiplug under it. Is that plug only for multiplex.
And on the topic of the multiplex system the MFD works in both 2000 and 2002 cars.
Re: Footwell wiring connector
FarmerPug wrote:I pulled away the carpet in the car im breaking to find no multiplug under it. Is that plug only for multiplex.
Re: mfd,itried one out of an o3 into a 99 it wouidnt work totaly diferent, :(
the o3 is for sat nav tho ,
was gutted to see sat nav and mfd carnt go in a 99 lx
This multiplex thing is making swapping bits over imposible :evil:
but my 00 breaker cars MFD went into my 02 exec and worked perfectly.
FarmerPug wrote:but my 00 breaker cars MFD went into my 02 exec and worked perfectly.
& your 02 wasn't originally equipped with sat-nav which would suggest that it isn't a multiplex issue, but more that the sat nav display isn't compatible with non-sat nav cars.
no my sat nav screen is just badly pixelated
lozz wrote:Re: mfd,itried one out of an o3 into a 99 it wouidnt work totaly diferent, :(
Was referring more to that.
Interesting, so the wet wally wiring can only happen on fully-multihex D9s, that's nice. :|
they wont work on my 99 vreg mate,
nor will the clocks swap over totaly different plugs on the back,
so ipresume the 99 model was the very early days of the d9 :?
but your 99 must surely be the same as my 00. The speedo clock for example has 2 plugs on the 00 car, my 02 car has just the one.
FarmerPug wrote:but your 99 must surely be the same as my 00. The speedo clock for example has 2 plugs on the 00 car, my 02 car has just the one.
theres more guages on the newer cars clocks :(
the lx just as fuel and temp, and the mileage screen. :roll:
and then my 02 gained a oil temperature gague
