Switch Or Motor Fault ?
my leccy seats seems to have some sort of fault.
if you look at the piccy arrowed orange. this function does not work the seat up and down
BUT if you press that bit down the seat slides back ? but its not meant to slide the seat back . its only meant to move the back section of the arse bit up and down
the passanger seat only slides back if you push the switch to the left.
is it a switch fault or motor fault ?
Re: Switch Or Motor Fault ?
ok just tested the seat again.
all the switch does arrowed orange is slides the seat back.
it does not move it up or down at all. just slides it back.
same as if you slide the switch to the left to slide the seat back ..
im thinking its defo a switch fault
Roylewaa
Post by Roylewaa »
It sounds like it could be a switch or motor fault there mate, If I remember when you push that switch either up or down at either end it should raise or drop the seat, basically like the extendable handle thats it that place on a manual seat
I had a base with all the motors tested and working and I gave it to the scrap man, otherwise you could have had it
Can you hear anything from the motors?
D8 2.1 TD saloon, oh yeah :)
ye mate. motors seem fine. just weird that the up and down function (arrowed orange) slides the seat back
even if you push it up to raise the seat it still slides it back :lol:
dealers switch price £150 :shock:
think i will take mine apart and fix it. there must be a way
Woody
Post by Woody »
I've got a pair of front seats with electric motors in. Cant sell 'em whole because os cig burns and heavy wear etc. But we tested all the motors and switches before we pulled the seats out and every thing worked. If I can help give us a shout. 8)
can i buy the drivers side switch unit please mate ?
were are you based ?
if the switch doesnt sort it i will buy all the motors for the drivers seat
my passangers seat is working fine.
well this may just be a big coincidence. but
im actually in rossendale 2moro :shock: from 10am probably till about 1pm ish .
i looked at your ebay store. would it be possible to call for the switch why im up there ?
im actually 3.5 mile down the road in rawtenstall ..
Woody
Post by Woody »
Yep! 'course you can! Let me have a good look at the set up, because it's burried under sheet loads of interior bits that I have, and I need to know how big and heavy it is for shippin'. Mondays I'm usually snowed under with order shippments from over the weekend so please call me on Tuesday when I've finished my weekendly nervious breakdown and started breathing again :roll: . I dont get on here as often as I need to, or like but... I will be only to glad to help you out. My phone number is 07792 202 428.
ok mate tuesday is good.
im actually only 3.5 mile away from your yard 2moro for a few hours getting my car repaired.
be a shame not to call and meet you and get the switch. i can always drive back up tuesday mate .
i can collect in person if that suites you .
Woody
Post by Woody »
P.m is good A.m so no good, but if your in Rossendale I will do my best just call me and I'll get back if I'm not drivin'
ok mate will do. i will ring when my car is finished ..
i have to be back in wigan before 2pm so it will only be a quick visit anyway.
how much will the switch be ?
Woody
Post by Woody »
Well it wont be anythingthing kie the dealer pirice of £150 :mrgreen: much... much less than half that :wink: I wanna keep you lads comin' back! 8)
less than half sounds good but how much less than half. :mrgreen:
i didnt even know you had a yard like that. your only 30 miles away from me so if i need out i will be back for sure.
