Hi there
I was wondering if someone can help me, I have a 406 estate 1.8 petrol 2000 , I am looking for a diagram or advice on where I could find the fuse for my window wipers ?
Many Thanks.
2000 W pug 406 fusebox
Re: 2000 W pug 406 fusebox
Greetings
It seems to be fuse 24 in the passenger fuse box (the one by your knee), the relay is, well, see if that's the right fuse first.
thanks m8. the fusebox is under the bunnet m8 ,do you think it will still be the same fuse you mentioned ?
There is or shouid be 2 fuseboxes,daviebhoy wrote:thanks m8. the fusebox is under the bunnet m8 ,do you think it will still be the same fuse you mentioned ?
the other en is by your knee drivers side
