Nightmare - D9 Schematics gone!!
This would be the site hosting the D9 fully multiplex schematics, all I get now is a page full of crap and a title that says "Contact Support". I guess whoever it was that was paying for the hosting isn't any more :(
The web addy was: http://www.petrila.net/pug/Service/index.htm, it now defaults straight to http://www.petrila.net/cgi-sys/suspendedpage.cgi
Anybody find it on there?
Oddly enough I was toying with a program for downloading whole websites and guess which one I tried it out on, it's not complete but it's better than owt. If they don't reappear on Petrila I guess I'll need somewhere to shove them (and preferably done by someone that knows what they're doing :oops: )
robb
Re: Nightmare - D9 Schematics gone!!
Post by robb »
Hi Steve done a search and can,t find it either :roll:
It's been taken down & reappeared at least once before. All we can do is try it periodically & hope.....
If it does, 'pop up' again, can such a thing be copied anyhow?
I reckon they've gone over the bandwidth limit; I wonder if a cached copy will work? I'll have a check.
Edit: Nope, no good. I tried the internet archive but it's not working :roll:
dogslife wrote:If it does, 'pop up' again, can such a thing be copied anyhow?
That's what I was trying to do, I was using WinHTTrack website copier, just the English and French (because some of the English stuff just says "not translated" or whatever in French) and only for the 406. I have spotted a couple of diagrams missing though (notably my engine ecu :( ), possibly because I'm not sure what I'm doing... Hmm, it's 112 megs :shock:
It's back up! Now, how do I download it?
stealthe
Post by stealthe »
steve_earwig wrote:It's back up! Now, how do I download it?
As far as I can see you just need to start a new project, and use [http://www.petrila.net/pug/Service/406/info/fr/sd9.htm] and [http://www.petrila.net/pug/Service/406/info/gb/sd9.htm] as the url's to start from. Remove the [brackets]. They both seem to link to the same images, so the total size wont be double.
That should give you a browsable copy on your pc, whether you would be able to move it or share it I couldn't say.
stealthe
As far as I can make out I've downloaded the whole thing, although I'm not sure what the huge disparity between size and size on disk is about:
Size on disk: 356MB
56,432 files, 81 folders.
I suppose all I need to do now is unplug me dongle and have a surf :shock:
stealthe
Post by stealthe »
The url's I posted would just be for French and English options from the site.
They give properties of,
Size 44.7 MB
Size on disk 59.4 MB
5213 Files, 12 Folders
The the difference between the sizes is because of the large number of tiny image files and the way that files are stored on the drive.
If you grabbed the entire site then you have the files for every language, and all the models listed.
stealthe
Allocation units are the granularity with which disk space will be allocated to files, so if you have a 4k allocation unit, a 1k file will be allocated 4k, and a 10k file will be allocated 12k. A smaller allocation size will give less "wasted" space, but will also be slower to access (actual data) due to increased MFT/FAT access.
Hmm, I've now got something similar but not identical - 5,215 files, which is probably the blurb Wintittytrack or whatever it's called shoved in there. During my surfette I did come across one pic I didn't have but it turns out neither does petrila :lol: So, we're not completely screwed if they disappear for good. Which reminds me...
Excellent work, gentlemen. :D
er... does that mean we've gorrit then?
No, it means I've gorrit :P
:cry:
I'd send it to you but it's a bit big for the old email...
Pity, you could've dropped it off a few weeks back. :roll:
