towbar
- lozz
Re: towbar
Hi & welcome,
Firstly some More info might help.
:What make of tow bar are you fitting,
:Are you wiring up single or Double electrics?
:Estate or Saloon..?
post up the Make of the Tow bar & iwill see if ican find you a (PDF) Diagram of the wiring,
Re: towbar
hi its a 99 1.8 saloon and im just wiring a single socket. I think its a 7pin will check also not sure on tow bar make how can i tell. Got it 2nd hand thanks dan
- lozz
Re: towbar
Hi best Route wouid be,
through the passenger side Rear corner, pull back the storage thing where the Cd changer sits and you shouid find a Gromet in the corner, thats how mines wired,
as for Tow bar socket - Wiring have alook at this link.
http://www.towitall.co.uk/towbars/wirin ... structions
it be just a case of looking at what colour wires go to the indicators Side lights /break lights shouid be easy enough to work out by looking at the wiring going into the clusters,
Youd be best Adding a fused link to all live feeds to imho
hope that helps if any.
Re: towbar
thanks 4 the help managed to sort out yesterday i used a headlight bulb an some wire to work out which wires to chop into all good thanks dan
