indicators
indicators
has anyone had this happen to their pug?
driving along as normal, and went to indicate, no lights or click from the flasher unit, then go over a bump then use the indicators and they work, had the switch cover off last night in work to check the plug on the back of the switch and was in tight and the indicators was working ok
anyone got any ideas?
jolly green giant 1.8 16v LX estate
- mjb
- Site Admin
Re: indicators
If it's a D8 I'd suggest you need to start looking for a replacement stalk. Shouldn't be too expensive for a used one...
- plod
Re: indicators
I managed to get a brand new one for £25 from the bay
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: indicators
One mysteriously fell into my pocket while rescuing a solid crank pulley from a 306 XUD. Odd.
Re: indicators
tried the old one in this afternoon as i replaced it when i fitted the front fog lamps and thats doing exactly the same thing, so cant see both switches being on the way out, grr french electrics lol
Re: indicators
It could be the connector on the back of the hazard switch. Or the switch itself.
- mjb
- Site Admin
Re: indicators
D'oh! I forgot about thatsteve_earwig wrote:It could be the connector on the back of the hazard switch. Or the switch itself.
- plod
Re: indicators
Sounds about rightmjb wrote:D'oh! I forgot about thatsteve_earwig wrote:It could be the connector on the back of the hazard switch. Or the switch itself.If memory serves you can't drive a 406 without a working hazard switch because it's required for the indicators to function. Much more likely than a stalk going for both directions
I had the radio, mfd, air con unit and switches out whilst painting and tried to drive off but had to pull over and reconnect the hazard switch back up before continuing
Bring back my 406
Re: indicators
well done chaps the hazard switch was on it last legs, swapped with one that found its way into my pocket from the scrappie everything working again now
Re: indicators
Well done Andy!andymacg wrote:well done chaps the hazard switch was on it last legs, swapped with one I recycled, everything working again now
Re: indicators
Splendid
The indicators are routed through the hazard switch on lots of cars
