JETS
Re: JETS
The mist ones are only suitable for the coupe as they sit on top of the bonnet
whereas the saloon and estate ones sit underneath
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: JETS- Midlands/South- FREE PINT
I'm a 406 saloon owner I swear
405s and 6's have got messed up windscreen wetting mechanisms- who wants to gopher a pint- midlands/south and sort my jets out?...
1996 406 Executive XU10J2CTE
1995 405 GLX XU7JP
1995 405 GLX XU7JP
Re: JETS
- rwb
Re: JETS
D8s have the squirters with two jets, D9s have misty squirters (I'm sure there are some D8.5s that break this rule).
I'm not sure whether they are interchangeable -- it depends how the squirter clips into the underside of the bonnet and attaches to the rubber pipe.
Edit: the clips look different to me: squirty | misty.
The two-jet-type-squirters are most easily aimed by using a pin in the end of the jet.
Re: JETS
poor discharge out of one of them, flow to both is rougly the same- I've switched them and one is not as good. And also they don't seem to hold any position I push them into- is that crap design?
1995 405 GLX XU7JP
1995 405 GLX XU7JP
- rwb
Re: JETS
I had that problem :cyclops:
A new squirter fixed it.
Re: JETS
What happened with the ones on my D8 was they got blocked, I pulled them off to blow them out and the clips on them broke
So I tried the mist jets off of my D9 as it wasn't doing much at the time (fegging registration bastards
) and they fitted fine. The only trouble is you can aim the D8 ones with a pin, the D9 ones are fixed and wash the bottom of the screen lovely
Re: JETS
I've got mist ones - std on later D9 saloons/estates, I believe.plod wrote:The mist ones are only suitable for the coupe as they sit on top of the bonnet
Re: JETS
Learnt something new today thendogslife wrote:I've got mist ones - std on later D9 saloons/estates, I believe.plod wrote:The mist ones are only suitable for the coupe as they sit on top of the bonnet
Subtle attempt at a distract from my error - Sam put up pics of his mum yet
Bring back my 406
