long shot 1.6 hdi 207/307 110bhp pinouts
adaptorman
Post by adaptorman »
i know its a 406 forium but as i fixed my last 406 treated myself to a 207 110 hdi which used to drive a treat until the battery was lose inside the cover(i had no idea) and its touched to earth on the ecu,no fuses blown and i assumed its possible ecu/bsi at fault?
pugged snap on pug planet 2000 in and came up with 2 faults aircon ,and injector curcit open short to ground,p1623(ill double check the code) now the vechical will only crank over and not start,dose anyone have a pinout for this ecu to try check things out.or what pin to check if possible :(
pics off inside ecu front/rear
Re: long shot 1.6 hdi 207/307 110bhp pinouts
Service Box seems to skip that fault code but from BBA - "P1623 Immobiliser code word / ID number Write failure " :shock:
I'm looking at could be the wiring diagram for your ecu (there's loads to choose from without specific details) but I'm not sure what you would be wanting to test - the injectors all have separate outputs, if there was a common fault with them it would be inside the ecu :(
leehdi
Post by leehdi »
adaptorman
first just have to say i dint expect a reply tbh :cheesy: secondly many thanks for the input/advise ,as tbh i know buggar all regards this type of ecu/bsi other then there a bloody nightmare, i have found a very very small part which has been melted of the board , which brings me to think its more of what you say a ecu fault,
question is ive found a few ecus but theres a few numbers differnert , but complete set up would be avaible ? ie ecu,bsi,key chip,transponder ?
but some say i need the clocks as well other say not ,which im not totaly tbh, i can only think of 3 options replace all the set up and see if it runs, send ecu off for a possible repair or try locate one with identical numbers(hard work) oh or fire the twat lol
leehdi
Post by leehdi »
In a 207 the mileage will be stored in the dash and BSI, so you'll need a ECU, BSI, Transponder and Dashboard. If you are going that route.
OR make sure the 2nd hand BSI has LESS mileage than what yours has
If you get a ECU, it needs to be exactly the same
If the ECU is dead, but the IMMO still works, then you can get a 2nd ECU [just the ECU] and I'll try and get you sorted with a guy who will copy the IMMO code off your old ECU and put it into the new one.
adaptorman wrote:first just have to say i dint expect a reply tbh :cheesy:
I actually find this sort of thing interesting :mrgreen:
adaptorman
i do if i can get my head around , i think pugs are harder then most vechicals to understand
just found this missing off ecu, maybe why it wount run ?
adaptorman
ps anyone which chip the immo is?
leehdi
Post by leehdi »
95160
adaptorman
leehdi wrote:95160
close only one near matching this is 951603?
bloody hell theres some right hdi nutters on here pmsl , nice one pal ,(next thing how the hell do you see the numbers :) theres so tiny lol
leehdi
Post by leehdi »
Sorry, looked at the wrong ECU like a plank
Its 95640 on the edc16c34
adaptorman
leehdi wrote:Sorry, looked at the wrong ECU like a plank
bloody hell ,lee i carnt find any chip with this number??? :cry:
leehdi
Post by leehdi »
What year is the car?
CAN-CAN or CAN-VAN?
Either should be 95160 or 95640, and flash file should be 2kb
adaptorman
leehdi wrote:What year is the car?
CAN-CAN or CAN-VAN?
hi lee , i personaly dont know which it is other then the ecu numbers/info above and ats 56plate 207,
adaptorman
only one emmprom as anything close which is 951603/understeath it says 9630w, you lost me on the flash file , unless you have it you can possble send , as im still pin checking as yet ..nightmare lol
