Oh joy how many relays, resistors & fuses just for the bloody fans !
Checked the fan - not seized, Checked the fuses - Not blown, Checked The Relays - All Working, Removed the Relays and cleaned all the terminals, did a continuity tests on all the pins, all fine, check the fan speed resistors - all good, even stripped the ecu apart to check it hadnt burnt out this part of the board..... Looked fine
Oh Peugeot, why do you decide to hide fuses !!! EVEN MORE FUSES UNDER THE MAIN FUSE BOX IN THE ENGINE BAY ! 40amp & 30amp fuse blown .....
