Ignition on - and Mirrors do a little dance.
This has happened a few times of late.........
I switch on the ignition and the mirrors do that silly dance and then go back to the memorised position like when you press on of the memories briefly.
Will this be another electrical gremlin of the 406
Re: Ignition on - and Mirrors do a little dance.
It happens sometimes on mine, not sure if its a gremlin or just french electrics!Welton wrote: Will this be another electrical gremlin of the 406
Also have problem with one of my power fold mirros not folding some of the time, worked for months, then stopped fopr a few days, worked again for week or so and not stopped!
Refitted it a few times but not difference!
1997 Honda Prelude 2.2 VTi
That's funny, my nearside mirror sometimes does not fold in.mbell666 wrote: Also have problem with one of my power fold mirros not folding some of the time, worked for months, then stopped fopr a few days, worked again for week or so and not stopped!
Makes you look a right doughnut when you pull up somewhere and one mirror gets stuck
You push it and it starts moving by itself all over the place
Seems to be better if you use them everyday, like the other stuff on the car....if it don't get used it goes on strike!!!
i tried pushing mine, but only after other mirror has folded. (i am not quick enough to run round to push mirror while still folding)
Not touched the memory buttons, i ve never succesfully programmed them. I tried when i first got the car but the just wanted to move my seat and not program!
In case you didn't know,mbell666 wrote:i tried pushing mine, but only after other mirror has folded. (i am not quick enough to run round to push mirror while still folding)
To memorise a position press and hold the M and 1 buttons together and a beep will be heard.
Do the same for No.2 if you want.
To recall a position, open the door and BEFORE you put the keys in the ignition briefly press either 1 or 2 and the seat will travel all the way to the stored position in one hit and then do the mirror dance at the end.
If the keys are in the you have to press and HOLD the 1 or 2 button until the seat has completed the move, otherwise it will only move in little bits each time you press the button, wierd buy hey.
Hope this helps
- niz406
- Admin <BR>Turbo God
My mirrors used to do this... I spoke to rmy local specialists and they told me of a few 406's with the problem, and continued to inform me that its not a cheap fix.... in fact I was informed that it's a replacement ECU job etc... in some cases, its been replacement switches ! Strange !
But mine hasn't done it for ages now !
Darn froggy electrics !
Mine hasn't done the mirror dance for over a week, until last night it was back again
One local French man said ''zat izz strange, I aff never scene zat before, yore miroars are furked, burt zi car izz byootiful no?''
I thought mine was bost! I'm going to try that out in the morningWelton wrote:To recall a position, open the door and BEFORE you put the keys in the ignition...
...If the keys are in the you have to press and HOLD the 1 or 2 button
Also one day (maybe the same day I fit these replacement rear brake disks and arch liner I've had sat around for months...) I'll get around to working what's up with the (un)heated seats
- Captain Jack
