Hi All
Wondered if this was a standard feature in the car, i pulled up today to wait for a work colleague turned off the ignition and removed the key but both passenger and driver front windows still worked BUT also the interior light doesnt work without the key in the ignition anyone had the same experience or know if and what the fault could be if any, veh is a 2002 2.0 hdi
Electric windows still working after removing key
Re: Electric windows still working after removing key
I think they're meant to work for a while after turning off - on mine you can hear the relay drop out about 60s after you turn it off
It's not a fault my 206 does this then stops if you open and close the door or after a time limit
- mjb
- Site Admin
Maybe it's a change they made to the BSI when they threw the COM2000 in - it's not the case on my '99 and '00 D9s.
Thanks it puts my mind at rest as im trying to find any issues it may have as hoping to get a few more years our of it
