Changing the battery
leestudd30
Post by leestudd30 »
Aside from the 3 minute rule, is it quick and easy to change the battery? I haven't had to change one on my cars for years lol.
omega
Re: Changing the battery
Post by omega »
nothings changed just make sure you know your radio code.
gumby6371
Post by gumby6371 »
Remove terminals, remove battery, position new battery, connect terminals....done.
If you've got the standard radio in a D8 you may need the radio code but that's about it.
leestudd30
Thank you! Is it possible to get a decent battery for a maximum of £40 from somwehere like Halfords? Prices have gone up where I work and its £44 for a 510CCA rated one now, was £25 2 weeks ago.
What's the 3 minute rule?
leestudd30
leestudd30
Got one from my parts department yesterday, £40 for a 510 CCA rated one which isn't bad. Going to fit it at lunchtime, I noticed theres some red plastic over the terminal on the right side. Don't mean to sound thick but is that purely to show which colour cable from the car to fit it to?, ie positive & negative etc?
StevieboyTD
Post by StevieboyTD »
yup
2.1td exec estate.
leestudd30
Cheers!
Busman
Post by Busman »
And to protect it from accidental shorts in storage.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
seanoconnell87
Post by seanoconnell87 »
What's the story with leaving the drivers window open? Is there a reason for it?
jonsowman
Post by jonsowman »
seanoconnell87 wrote:What's the story with leaving the drivers window open? Is there a reason for it?
I believe it's so you can reach in and turn the headlights on - opening the door would mess up the procedure at that point.
leestudd30
Changed it lunchtime, started much better than before! Though I noticed that when you press the drivers door window switch to go up it only moves about an inch then stops, whether I hold the switch down or not.
Keep your finger pressed on the button -for a few secounds after the window as closed
hold it until you hear a faint click sound,
This shouid Re-set it,
leestudd30
Thank you, will do that later!
