Hi all
I have a Peugot 406 2.0 D8 from 1998. When i start the engine the two cooling fans in front of the radiator starts shortly on low speed and then change to high speed and stay there constant. I have checked the brown gauge at the thermostat housing and it seems okay. I suspect a problem on the pressure switch at the top of the aircon dryer. Does anyone know how to check this one. Can I take af the plug of when the engine is startet.
406 aircon problem
Re: 406 aircon problem
It was a loose wire under the fuse box in the cabin and a blown Fuse number 12, 15 amp. I am so happy it is now working.Karl wrote:Hi all
