how do i get more boost on the turbo?
I believe the turbo can only run at 14 psi on the 8v Sri turbo engine, any higher it goes into limp mode, how have people got round this issue? I,LL be fitting a bigger turbo and im wanting to run higher boost, many thanks for any help
- jamjar1383
Re: how do i get more boost on the turbo?
you will have to have the ecu mapped if your gonna run the bigger turbo and then you shouldnt have any problemsthebenny wrote:I believe the turbo can only run at 14 psi on the 8v Sri turbo engine, any higher it goes into limp mode, how have people got round this issue? I,LL be fitting a bigger turbo and im wanting to run higher boost, many thanks for any help
d9 hdi 90 rapier estate
