Hi there
I hope to be a new owner of a 2.0 HDI Exec soon...
My question relates to the instrument panel service interval mileage display (with a spanner symbol next to it)...
Does this mean that only a Peugeot main dealer can service the car and in so doing re-set the mileage interval until the next service?
I would hate to stop using my trusted back street independent garage and have to pay exorbitant main dealer rates...?
Your thoughts please.
Steve
Service Interval Display
Re: Service Interval Display
depends on year m8,i have a 2002 and if i put key in and then keep my counter reset button depressed for about 10 seconds it resets it back to 12500 miles before it needs a service and will get rid of spanner for u m8,renault have same sort of thing when i had my laguna.hope this helps m8 dont know if older pugs will be the same,just try it,then u can service it when u want.
I'm a mk1 owner so no such concerns for me but after a quick search;
Q: I Have Performed My Car's Service Myself, How Do I Remove The Service Spanner?
A: Perform the following
? Turn the ignition off.
? Press and hold the milometer push button (the right hand push button on the dash)
? Turn on the ignition (do not start the car!)
? Wait for the display countdown to reach 0
? Release the milometer push button
Turn the ignition on and check that the correct mileage till the next service is displayed.
Hope that helps
Hope that helps
Sounds like perfect answers gents, thanks.
The one I'm thinking of buying is a 2001, so I suspect these instructions will work.
Cheers
Steve
Cheers
Steve
- 1.6 8v
I believe the service reset instructions are in Autodata, which I have a copy of, so let me know if it works or not and I can have a look if it doesn't.
Peugeot 406 HDi 110 LX Saloon D9 110k miles, although dash now says 121k
Jobs list: Fix ECU, reprogramme stereo to stop the dreaded beep, reprogramme key to re-enable remote central locking.
Located: Leicester
Located: Leicester
Thanks Steve
What's Autodata by the way...?
Steve
Steve
