Airbags
xplosiv
Airbags
Post by xplosiv »
Hi,
Dam French electronics, I got my car back from the mechanic after fitting a new rubber thing to my gearbox, which has solved the shaking at 60mph+. But now I have an intermittent airbag fault.
After driving for a few minuets the airbag light starts flashing and stays on. When I arrive at my destination and turn the car off leave for a few seconds and turn it back on the airbag light has gone out, but then after driving it starts flashing again.
I am guessing an electrical plug has come lose, anybody had the same problem and if so how do I fix it.
Many Thanks for your help,
Andy
NOTE:- Car is a 406 HDi (D9 – new shape) 2.0L 110BHP LX V reg (1999)
Edit: after looking on the forum i found that the wires under the seat can come lose i had a look but found all of them to be ok, althoug i did find two wires not connected (please see picture)
Just give'em all a good wiggle, there is one at the back of the chair aswell.
Worked for me :cheesy:
xplosiv
Post by xplosiv »
any ideas about the two wires in the picture that are not connected ?
andy
Just for you, I'll have a look at mine and post up a pic for you (tomorrow).
GeordieBoy
Post by GeordieBoy »
The 2 wires will be either for electric seats and/or heated seats.
My Airbag light stays on all the time, but a m8 says its not an MOT failure.
So I aint too bothered.
Vehicles I own:-
GeordieBoy wrote:The 2 wires will be either for electric seats and/or heated seats.
Tut tut Geordie, Have you looked at the connector under the BACK of the seat? mine was a bit loose, but can't say if it actualy fixed my airbag light (which has not come on since).
dervpower
2.2 16v
Post by dervpower »
my side airbag light was lit even though theres no sign of sideairbags but thats another stor!!!!! i disconnected the battery closed up the connectors using small screwdriver and wrapped them tightly in insulation tape and lights bn off ever since and that lights been on for approx 5years as my dad was the previous owner
We had a very long discussion on here about side aribags, My seat base has a sticker on it that says side air bags, but no light on the dash, some people have a 'patch' on the side of the seat saying 'side air bag' but I don't.
Apparently though, on seeing a programme the other night you can have side airbags, you wouldn't know they are there but the stitching on the side if the seat is designed to burst open as the bag deploys. I'm sticking with my theory that they are fitted to mine.
Anyway, here's my under seat wiring........
And, the connector I mentioned at the back of the seat, which was loose.....
dervpower
2.2 16v
Post by dervpower »
aint peugeot wiring great!!!! whod have thought that the underseat wiring could get knocked with it been so neatly tidied away!!!!! yeah i remember the discussion welts im unsure if my pugs got em no other evidence barring the light but if ive played with connections and the lights gone off that must be pretty conclusive ?
dervpower
2.2 16v
Post by dervpower »
by the way geordies right airbag light not a mot fail as i took mine thinking it would be and the tester pointed out thats its not but an engine management is,apparently its ok to die in a car crash as long as your car wasnt polluting the enviroment beforehand!!!!!!!!!!!!
xplosiv
Post by xplosiv »
Welton do you have elec seats as you seem to have loads more wires than i have?
andy
NB: thanks for the picture
They are leccy seats, and ALL that lot are connected up :shock:
I'm not sure the pic is that usefull, sometimes manufacturers put wiring under the seat for standard equipment specified for other EU countries like seat belt warning light etc etc.
The red one with the single green wire IS connected to another connector of the same colours, the white one with the 2 greens, I don't have :?
Under my seat there is a seat ECU with a cover and vent-holes, I doubt Peugeot would pre-wire all that lot for all the 406's ?
