Electric window
Electric window
Right my passenger window has become a norze everything has been working fine till today I try closing the window but nothin leant over to use passenger switch worked fine but now every time I start the car in opens on its on accord drivers side switch don't do anything does make a clicking noise I did close it while I was drivin down the road by leaning over but 2 mins later straight back open again
Re: Electric window
Might it be stripped wires where it goes through the door
Damn weird fault though!
Re: Electric window
It is a bit strange I'm going to try changing the switch to see if that has anything to do with it
Re: Electric window
Similar thing happened to me , tried everything up to and including changing
the passenger switch turned out to be drivers switch .
Re: Electric window
Well it's only the driver switch that ent working so gonna give it ago first hopefully it works
Re: Electric window
Ok so my disconnected the driver side switch and it still does it the other problem I got is I've put d9 door cards in so diffrent switches but the drivers door has still go the d8 driver switches
