Name that cable
Syncros
Name that cable
Post by Syncros »
Is anybody familar with that this is?
Diablo 99' 406 HDi 110 Executive 8)
Busman
Re: Name that cable
Post by Busman »
Can you give us any more info, such as where it is? But be carefull of the old issue that they put in lots of cables and plugs that are not used on all specs or models. You'll find a few more unused in the engine bay if you hunt them down. It's a mass production thing, it's easier to fit the whole lot rather than have many different looms.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Syncros
Re: Name that cable
Post by Syncros »
I found it while rumberging through the head unit caverty. It was located to the rear upper right, by the looks of things coming down from the instrment panel.
MJBD8
Re: Name that cable
Post by MJBD8 »
Sat nav antennae?
Syncros
Re: Name that cable
Post by Syncros »
Yeap 8)
I just found the other end in the boot under the JBL amp. Although with the satnav loom.
