Taken my key apart today to replace the rubber buttons and now it wont work the light comes on when i press the unlock button does anyone know the procedure to re sync
thanks matt
key re sync
key re sync
Petrol executive 2001 model Running on L.P.G
- DaiRees
- Site Admin
Re: key re sync
There are a couple of different options on this, the one I used to use was to put the key in then press and hold the big button while turning the ignition on, keeping it pressed for 10 seconds.
I've also found this one
Have a search using the box at the top right, there's loads of info on this....lozz wrote:RE SYNC:
1. Turn the Ignition switch ON.
2. Press the large Plip key button (Primary Plip)
3. Within 10 seconds press the large Plip key button (Secondary Plip)
4. If there is one remote, press the Primary plip button twice.
5. Turn ignition OFF.
6. Test Plip’s for correct operation.
