Little Query !!
- puggy
- Resident Pervert
Little Query !!
When sitting in my car with engine off and i want to operate the windows
i have to start the engine just turning the key to ignition on doesn't work ,does
everyone have to do this ??
- Site Admin & Mad Biker!
Re: Little Query !!
Hello and long time no see Puggy!
Sounds weird, usually you just turn it to the acc position to operate the windows
Didn't you change the ignition barrel some time back? Maybe worth checking the connections.
Re: Little Query !!
Grettings puggles
Mine work on the acc positition, (& for about a minute after you turn it off).
Re: Little Query !!
...unless you open a door.Doggy wrote:(& for about a minute after you turn it off).
- puggy
- Resident Pervert
Re: Little Query !!
Thought i remembered they used to work like that shall have to investigate .
A special hi to teamy , yes long time no see hope all goes well , and thanks for
the input lads , not been around cos been in hospital , recovering now so
should be able to add some smut filth and general good perversion
Re: Little Query !!
Crikey Lou, all ok? Were you giving the nurses merry hell?
I have a suspicion you should check your fuses.
Re: Little Query !!
As Steve says I hope everything is ok Lou
All the best
Matt
All the best
Matt
- puggy
- Resident Pervert
Re: Little Query !!
Thanks lads
i had a abdominal aeortic anurysum and 2 more in me groins
and they had to be done before bursting
the 2 in my groins led to the
nurses having to move me willy while each time they changed me dressing mmmmmm
ecstacy
Seem to recall this window problem started at the same time as the wipers
decided to get a mind of their own
ecstacy
Re: Little Query !!
puggy wrote:Thanks ladsi had a abdominal aeortic anurysum and 2 more in me groins
and they had to be done before burstingthe 2 in my groins led to the
ecstacy![]()
Get well soon Lou, take it easy!
All the best to you.
John.
- puggy
- Resident Pervert
Re: Little Query !!
Cheers John , hope you and your good lady are doing well and of course jasper
Re: Little Query !!
Get well soon Lou, (the smut and inuendo have been well below par recently).
Oh, and either slow down for the speed bumps for a bit, else get a couple of cushions to sit on.
- puggy
- Resident Pervert
Re: Little Query !!
My God doggy you never forget !!
i now do my best to avoid using
them as launch ramps
Re: Little Query !!
We're fine, thanks Lou, Jasper is doing alright, but he's almost blind nowpuggy wrote:Cheers John , hope you and your good lady are doing well and of course jasper
Re: Little Query !!
...hadn't noticed that, so checked - seems to work until you open and close a door.steve_earwig wrote:...unless you open a door.Doggy wrote:(& for about a minute after you turn it off).
