battery running flat
swampyv6
Post by swampyv6 »
hi all,
got an issue with my 406 v6 coupe (S plate se model) the battery keeps going flat after a few days.
whan running i have 14v plus across it so can rule out an alternator issue.
the aftermarket stereo has being disconnected.
now, when i was drivinbg the car last i could here a really keep ticking , it sounded to be from behind the rear qtr panel on the drivers side, is there anything in this area that could run it down?
Re: battery running flat
Not sure on coupes, but 'straight' 406's have the JBL amp & satnav in that area.
If you can, leave the battery disconnected - if it still goes flat, there's your culprit.
For a quicker answer, disconnect it and measure any current flow when everything's off. Remember to allow enough time for the ecu to 'go to sleep' after turning everything off, (15 mins)?
Doggy wrote:Not sure on coupes, but 'straight' 406's have the JBL amp & satnav in that area.
Tis passenger side on the coupé
Disconnect the battery first, see if it's committing suicide.
We did have someone a while back with a misbehaving split charge relay there, although it wasn't a coupé...
swampyv6
Post by swampyv6 »
so charge the battery then leave it disconnected and see if it runs down again?
swampyv6 wrote:so charge the battery then leave it disconnected and see if it runs down again?
That'll certainly tell you whether it's the battery or not.
swampyv6
Post by swampyv6 »
well i charged the battery, and left it disconnected from the car and it went flat again!!
so new battery time, put the feelers out at work and i have managed to get an ac delco one, three years guarantee for £42!!!!
