Wiper fuse
DAS68
Wiper fuse
Post by DAS68 »
Hi- My wipers have stoped working, I need to check the fuse and I have located the fuse box under the steering wheel but dont know which fuse it is for the wipers, I dont have a haynes manual as yet can any one help?
Re: Wiper fuse
From user control panel - 1996 406 1.9 D LX (saves other people checking :wink: )
Hi there, it seems to be fuse 24 (30 amp). I'm not sure how accurate the fuse diagrams in Haynes will be for your car but I suspect not very :( I got that fuse location from here - http://www.peugeotlogic.com/#fuses
DAS68
Re: Wiper fuse
Post by DAS68 »
Many Thanks I will try it now
DAS68
Re: Wiper fuse
Post by DAS68 »
Thank you very much, you were spot on!
Re: Wiper fuse
Excellent :cheesy: The question is: why did it blow? :frown:
jonsowman
Re: Wiper fuse
Post by jonsowman »
FWIW, Haynes is actually correct on this one.
Passenger Fusebox - F24 (30A) - Windscreen wiper, heated rear window, cruise control.
Could it be the heated rear screen that caused it to blow?
