pin pad codes
pin pad codes
hello could anyone tell me if i can change the start code for a p reg 406 from automatic to manual, i,m afraid i don't have the original 4 digit code. is there anyway around this.Thanks
Re: pin pad codes
If your talking about the immobiliser ie the keypad, I can check my manual tonight and post tomorrow what it says. But if you haven't the code I doubt you can get hold of it. Like others on here the keypad for my immobiliser is disconnected anyway and I have no code for it.
Re: pin pad codes
Re: pin pad codes
i looked at handbook and you need original code to change it, is it easy enough to deactivate the immobiliser?
Re: pin pad codes
It is! Start the car and while its running pull the plug out of the back of the immobiliser keypad, thats it!
Re: pin pad codes
thankyou very much. that is most helpfull.
Re: pin pad codes
just pulled the plug on the immobiliser job well done thanks
Re: pin pad codes
I looked at the back of the immobiliser keypad on my D8 and the loom doesn't look like it can be unplugged. Any ideas how to bypass this annoying box?
Re: pin pad codes
When the immobiliser works it stops the fuel supply doesn't it? Is there anything on the fuel pump that can be removed to bypass it?
