Hi, my speedo on my 2002 406 stopped working, not the entire dash, but just the speedo
Some say its the sensor sitting on the gear box - can someone explain where it is exacly and what do i have to do to replace it?
406 speedo stopped working
Re: 406 speedo stopped working
This issue has happened to a couple of members here, seems to be a common issue. I had it fixed about 6 months ago, myself.
Have a look at the previous discussion:
viewtopic.php?f=3&t=19699
Short story is: If you experience a drop in power while the speedo stops working, it's either the speed sensor on the gearbox, or the BSI (I think, it's the speedo control unit, I think it's part of the BSI).
Luckily, it's a relatively cheap part.
2000 406 TS4 2.2 saloon
Hi, my 406 is 1.8 petrol and not a diesel and i do not feel any loss in power
It's exactly the same sensor on petrols and diesels, mine's a petrol 2.2.
If you don't have any loss of power at all, it's probably a faulty connection in the instrument cluster. You either need to disassemble it and fix the connection, or find another cluster to swap in.
Where exacly is this cluster located?
Behind you speedo:) There's some soldering involved, not really hard to do.
Land of the Free?
