''Dead Lock''?
Sonia406
''Dead Lock''?
Post by Sonia406 »
When I had my handbook (I've misplaced it....) I remember reading about the little button on my fob which is apparently a ''dead lock''
What is the point of this and how does it work? Does anyone actually use it?
I've recently had to replace the rubber in the fob and it got me wondering....... :lol:
Miss Pug 2001 - 2023.
trem1
Re: ''Dead Lock''?
Post by trem1 »
It means if you deadlock your doors you can leave your kids inside and no matter how hard they try, theyre still there when you come back
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
trem1 wrote:It means if you deadlock your doors you can leave your kids inside and no matter how hard they try, theyre still there when you come back
I see - so do you press the dead lock button after you've already locked the car? How do you know deadlocks worked? Then to unlock do you press the deadlock button then unlock as normal?
Do you use yours?
Busman
Re: ''Dead Lock''?
Post by Busman »
It all depends which key type you've got. Being a pug it's not straight forward!
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
I've got this key........... :D
trem1
Re: ''Dead Lock''?
Post by trem1 »
yes i use my deadlock pretty much all the time.On my 407 i press the lock button twice within a second or so and you hear the locks operate twice. to unlock its just a single press to unlock, its been awhile since i drowned my 406 :cry: so someone with more recent knowledge will be able to update you on yours
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
trem1 wrote:yes i use my deadlock pretty much all the time.On my 407 i press the lock button twice within a second or so and you hear the locks operate twice. to unlock its just a single press to unlock, its been awhile since i drowned my 406 :cry: so someone with more recent knowledge will be able to update you on yours
Awww :( RIP 406 :(
Thanks Trem!
Re: ''Dead Lock''?
Deadlocks are mainly to prevent people from breaking a window & letting themselves into the car as they prevent it from being unlocked from the inside. Bearing in mind how temperamental French electrics can be & speaking with experience of a Peugeot (& old Mondeo) which had door lock issues, I wouldn't advise using them at all.
If you press the small button, the deadlocks will activate, but I think you only have to press the large button to unlock.
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
waue1978 wrote:Deadlocks are mainly to prevent people from breaking a window & letting themselves into the car as they prevent it from being unlocked from the inside. Bearing in mind how temperamental French electrics can be & speaking with experience of a Peugeot (& old Mondeo) which had door lock issues, I wouldn't advise using them at all.
Well, there is that isn't there... however I do have an urge to go play and see :lol:
Re: ''Dead Lock''?
Stu is right, the deadlocks are there as a secondary lock to keep your car safer. I always use them but that's because I can.. 8)
I used to have an old Mondeo ( £140 from eBay ) which was a good car, went like the wind but I tried to use the deadlock on it and it worked - once. I could not open the doors at all, I tried everything and had to just use the boot for getting in and out for a week. Eventually forced the lock to turn with the key in the drivers door and the passenger door but both rear doors stuck fast.
Just kept it unlocked in the end... :wink:
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
GingerMagic wrote:Stu is right, the deadlocks are there as a secondary lock to keep your car safer. I always use them but that's because I can.. 8)
Ok, since you too have a 406 and have a dead locker... Please explain the process to me...
Lock normally then press the little button yes?
How do you know if it is successfully dead locked?
Re: ''Dead Lock''?
Sonia406 wrote:Lock normally then press the little button yes?
Big button then little button within a few seconds. You'll hear a different noise coming from the central locking when you press the small button as the interior handles are disengaged, and depending on the alarm type, you may see a long flash of the hazard lights signifying the alarm's now active.
Re: ''Dead Lock''?
What about the later ones, (with just a lock & an unlock button)? :?
rwb
Re: ''Dead Lock''?
Post by rwb »
With this key:
The big button deadlocks (and a second press locks normally), and the small button unlocks.
When you press the big button to lock the car you can clearly hear two clunks.
If you press the big button when the car is already locked then the indicators flash.
Re: ''Dead Lock''?
On mine ( 2004 ) I just press the lock once - you will hear a clunk - then press again straight away and you will hear a second clunk, slightly different from the first. Simply unlock as normal with a single press of the unlock button.
Both clunks have a single flash from the indicators.
