Battery warning
rwb
Battery warning
Post by rwb »
Can't remember exactly what the message said, but the battery light came on.
There's an intermittent fault stored in the BSI, but that's all.
Parameter measurement suggests everything is good.
Top: engine off. Bottom: engine running.
Started up and drove 10 miles with no further tantrum, so I'll let it develop :roll:
Otherwise it's had a good day. Trip to Southampton this morning got 61mpg on the computer, and the air con is working magnificently -- radiator fan and all :D
If this rings any bells then it would be good to know what happened.
grasmere59
Re: Battery warning
Post by grasmere59 »
I had "battery voltage low" on the MFD and the battery light on a while back and it was the alternator on the way out,changed the alternator and all is good again.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: Battery warning
It's also worth making sure your quick-release battery terminal(S) are good and tight.
...and maybe check the main earth connections too?
grasmere59
Re: Battery warning
Also check the alternator clutch pulley if yours has one as they can loose drive.
