How do I wire a 12S towing socket
darts180cars
Post by darts180cars »
Hi,
I have a Peugeot 406 estate with a standard tow bar with 12N electrics fitted, but I wanted to wire in the 12S socket as well so I can charge my caravan battery. I have searched and searched the Internet for instructions, but cannot find any that are of use. I need to know what parts .I need as well as how to do it. I already have the fitting plate, and 12S socket. I am fitting this for the gray plug on my caravan (Post '98).
All help is greatly appreciated.
Thanks.
2002 (52) Peugeot 406 GLX HDI 180bhp Estate Met Red 2.2l
jasper5
Re: How do I wire a 12S towing socket
Post by jasper5 »
Hi, Welcome to the forum :D
Have you seen this?
http://uk-trailer-parts.co.uk/7-pin-s-t ... van-wiring
darts180cars
Hi,
Yes I did have a look at that, it was helpful, but it does not tell me what parts I need, it seems that I need a relay to go on the car, fuses and some plugs to connect to the wiring harness, but i do not know which ones!
jasper5
Post by jasper5 »
These people sell wiring kits and all trailer and caravan towing stuff......http://towsure.com/category/Universal_T ... ing_Kits_2
Maybe you should go to your local caravan shop?
grasmere59
Post by grasmere59 »
This is what I used when I wired my 12s plug http://www.ebay.co.uk/itm/SPLIT-CHARGE- ... 10dd96,i'm not sure what year your car is but on my estate (2003) on the multipin plug that feeds the O/S rear light cluster there is a large red wire on the plug that is a dedicated feed for the towbar/charge wiring,i think it is there for when you use the specific Peugeot wiring kit (it goes nowhere in the light cluster)I fitted a fuse in the cars fusebox (it tells you in the fuse data in the handbook which one) and cut it from the multipin and used it via the relay to power fridge when towing,i don't think wire is man enough to charge the caravan battery and the fridge while on the move but all I needed was the fridge to be working.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
darts180cars
I went to my local caravan shop and bought a Maypole Auto switching kit for £20, and managed to wire it in and all is now working. Thanks for your help.
