Battery changed in key fob - now nothing
Waxman
Post by Waxman »
Hi All
Central locking working ok, went to lock the car just now and it wouldn't lock.
thought I'd change the battery ( new correct style/number replacement ) in the key fob ( key style shown below )
Just changed the battery and now the LED does not light up when you press it and it does not operate the central locking.
( the LED was flashing red with old battery, so tried the old battery again and nothing - not even LED flashing )
Key still opens the door manually ok and starts the engine ok
Thoughts / Help ?
The Rubble Shifter: 2.0 HDi 110 GTX 406 Estate, Tuning Box, K&N Filters.
Thunderbird 4: Mercedes AMG E55, Full Decat & Res Delete.
*New Addition* The Roller Skate: VW Polo GTi
markw
Re: Battery changed in key fob - now nothing
Post by markw »
I know you have to re-sync the key to the car when the battery is changed otherwise the car doesn't recognise it, but the LED should be doing something anyway.
No disrespect, but is the battery in the correct way round?
Waxman
Post by Waxman »
^^ Thx
The car still recognises the key ok - i.e it starts it
Battery replaced the same was as I saw it '+' facing upwards.
New battery tried and old battery tried but no LED flashing ?? - As I said, prior to opening key it was flashing...
Waxman
Post by Waxman »
- SOLVED -
Big fat fingers here had pushed one of the battery terminals down ( so not touching circuit board )
tweaked it back up, closed key & light started to flash - Woop
So done sync in car and now working ok.
lol :wink:
markw
Post by markw »
A self fix!
Just for info, the electronics in the fob are only for the locking/alarming of the car. The immobiliser chip in there is separate and passive (ie not battery powered) so as you found out, you can start the car but can't unlock it remotely. 8)
