Diagnostics Socket
tiggercl
Diagnostics Socket
Post by tiggercl »
Hello,
Can anyone advise 'exactly' where the diagnostics socket is on a 2000 model 4006 V6 sedan?
Previous posts have mentioned that the socket is located under the steering wheel panel (on the right).
If this is the case, then left or right of the fuses?
Cheers
neildavies
Post by neildavies »
It's behind a blank switch panel above the fuse box. On some cars, there's an ESP switch on the left, then a blanking plate on the right. (Sorry, I'm assuming your asking about a D9)
2007 307cc Sport 2.0 HDi 136
tiggercl
Post by tiggercl »
Champion !
Found it .. right next to the cruise on/off switch !
Cheers
neildavies wrote:It's behind a blank switch panel above the fuse box. On some cars, there's an ESP switch on the left, then a blanking plate on the right. (Sorry, I'm assuming your asking about a D9)
neildavies
aha, that'll be a D8 then. Glad you've got it.
aliaziz
Re: Diagnostics Socket
Post by aliaziz »
Hi,
Would anyone know which diagnostics cable/interface would work with 406 coupe 3.0 V6?
thanks
aliaziz
Post by aliaziz »
ITs a D8
