My coolant light flicks on now and again but levels are fine so I just grabbed one from a breaker while I was getting some trim bits and pieces. It has a bit of scale on it and I want to clean it up before fitting.
Will descaler damage it?
Only cost a quid so worth a punt!
Coolant sensor cleaning?
Re: Coolant sensor cleaning?
If you're worried about the descaler you could use vinegar...
(answering the right thread this time hopefully
Thanks Steve I was thinking lemon juice but same difference
Success! cleaned up my £1 coolant sensor andfitted it and no warning light for 48 hours.
The old one flashed on and off with every journey so that's job done
Splendid
What did you use as descaler in the end?
50/50 lemon juice and hot water, that's what i use on the pet water fountain when the pump clogs
What sensor was it? the one on the expansion tank? Mine started beeping Christmas eve when engine is cold or warm, not been far in it but the wife just came in and said it's doing her nut in... Great timing we're suppose to be going away in it tomorrow.gumby6371 wrote:50/50 lemon juice and hot water, that's what i use on the pet water fountain when the pump clogs
Expansion tank sensor mate, it has thrown the light up once since I swapped it but it was flashing on and off every journey so its a massive improvement
Not sure if this is a new one or not but mine seems to do it when the front windscreen demist button is on.gumby6371 wrote:Expansion tank sensor mate, it has thrown the light up once since I swapped it but it was flashing on and off every journey so its a massive improvement
