cruise control woes
jonny81191
cruise control woes
Post by jonny81191 »
The cruise control has died on me :(
It was working perfectly, and has just stopped. The only thing I have done is to fit studs and spacers to the rear, and I noticed as I arrived at work that the ends of the studs are just touching something in the rear handbrake drum. But I don't see that being related.
Which fuse do I need to check?
Any other suggestions?
Edit: it's a 110 hdi executive
jonsowman
Re: cruise control woes
Post by jonsowman »
Very common cause is lack of coherence between the two brake switches.
Sorry for brevity, am on phone - have a search on here for more info.
jonny81191
Well it's fixed itself now. Bloody French electrickcsz
The other common one is a slow-to-rise clutch pedal - if it happens again try lifting the pedal with your toe / try again.
My previous 406 used to do this for no good reason, maybe twice a year but always fixed itself for the next journey.
jonny81191
Doggy wrote:The other common one is a slow-to-rise clutch pedal - if it happens again try lifting the pedal with your toe / try again.
I reckon you've hit the nail on the head there TBH, as I arrived at work, I noticed the clutch was lower than normal (CJ mentioned to me about the issue when I got the car) so I just pulled it back up with my foot. After work, it was working again.
Jonny, did you get the master cylinder yet? I really wonder if it will fix it. Or whether it's the weak spring under the pedal...
Both look rather awkward to replace though....
jonny81191
Yeah, thanks for that. I'm not having any issues really, its only happened the once. I'll fix it at some point :lol:
Yeah I was going to as well. Had the master cylinder for 4 years and never got around to it............
dave406
Post by dave406 »
See had an issue with my CC and the car cutting out under load it chnaged my MAF issue resolved - unplug it see if it helps
