Anti pollution fault
lionyo
Post by lionyo »
I have 406 2.2 HDI 136BHP Saloon and have the Engine management light and anti pollution fault.
It went off after a few motorway drives but then comes back on when it is taken above 2500rpm approx.
So far I have replaced the Swirl flap as that was broken, swirl flap actuator sensor and the denso sensor that is on the passenger side above by the headlight.
Are my vacumm pipes fitted right way? Anyone take a look at there car and compare with mine?
lionyo
Re: Anti pollution fault
Post by lionyo »
No one to point me in the right direction?
might be some useful pics on here,
not sure tho,
worth alook,
link http://translate.google.co.uk/translate ... %26hl%3Den
lionyo
Post by lionyo »
The first two valves are same part number 9628971180 is this right?
I've circled the two that the same part number below? Isn't the secound one supposed to be 1628LQ?
Hi, Finchy is the best one to talk to on the ' other side ' as he knows the Hdi inside out.
Just to test though, you can swap the 2 pipes and the electric connector from the left EV ( turbo ) to the middle EV and vice versa and see if it helps. The pipes are correct so you have a reference point to come back to.
Is the tiny pipe from intercooler to the Denso sensor okay or perished?
I personally think this could be related to the fuel pressure sensor as it happens at higher revs, although I am no expert.
nutski
Post by nutski »
The part number for all those bulkhead EV's are 1628.HC and swapping the left and middle ones is a good idea for a test (although if both have an issue it doesn't help!), another area to check is the vacuum chamber in front of the brake servo, small black plastic chamber which has three vacuum pipes enter the bottom of it, i've know these to fail too and cause the same issues by slightly leaking vacuum, when mine was swapped on my old Coupe one plastic pipe was so brittle it broke away trying to remove the vacuum pipe.
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
