12v socket
12v socket
Just a quick one ....if I want to replace my cigarette lighter with a 12v USB adaptor is as simple as just removing and replacing ?
Using Tapatalk
Re: 12v socket
I can't think of anything else you'd need to do
Maybe check the polarity but I believe it to be impossible to get it wrong as the connector only fits one way.
Re: 12v socket
I'm talking about removing the complete unit and retrofitting a complete new unit
Using Tapatalk
Re: 12v socket
Ah, I presumed by adaptor.. I've only seen the ones that plug into the the lighter socket so I've no idea. Any chance of a link?
Re: 12v socket
All that is is a fag lighter socket with a lid
Re: 12v socket
Lol , nowhere near as deep but it only has two wires where as the pug has three in the connector do this is what's throwing me
Using Tapatalk
Re: 12v socket
the quick way. http://www.maplin.co.uk/p/12-24v-micro- ... pter-a50jk
9.99 might be cheaper else where,
Re: 12v socket
Brown 12v+ve (power)hallsie wrote: the pug has three in the connector
Green/Yell 12-ve (earth)
Orange illumination
Re: 12v socket
The plug in adapters are only a fiver in petrol stations. I have a couple of them and so far so good they do the job, even in the 24v lorry.
Re: 12v socket
2.99 on ebay,
most probs 99p in one of them cheap'o quid shop things.
Re: 12v socket
See my problem.no mater what charger I use my phone.says it's not getting enough power to charge and be.used as a sat navigation
Re: 12v socket
Yeah I'm being a bit fussy and want to do a proper job ...the cig lighter in my car is disgusting and has been very well used ( not by me ...never smoke in my cars ) !
Using Tapatalk
Re: 12v socket
Can it be washed? I'd still go for the original as if you replace it with something for 99p you'll probably have to file the hole bigger, chop off the connector and use mickey mouse spades and loose the illumination. These 99p jobbies are for putting another socket elsewhere in addition to the car's existing lighter socket, in the glovebox, boot or wherever.
Re: 12v socket
I've got the 2 amp version, which is fantasticlozz wrote:the quick way. http://www.maplin.co.uk/p/12-24v-micro- ... pter-a50jk
