I have had a problem with the switch as long as I have had the car. Like most people it seems.
All the other swicthes work fine.So is it possible to get another switch from the breakers and fit it in the drivers door hole .
I am checking if the other swicthes will fit in the hole.I have also seen people mention that can you get the switches reconditioned .
Any recomendations.
Eventually got the window up after 20 mins button pressing Not the best game to play in the rain. phew.
Drivers Window Wont Go Up
HDI RAPIER BLUE D9 2001
Re: Drivers Window Wont Go Up
I had this issue with mine originally. If I was going to a drive-thru I had to start pushing the switch to make the window go down when I was about a mile away......
Try a known working switch first, they are fairly common on eBay and local scrappies...
Hi
See viewtopic.php?t=19580&p=194716#p194716
Circuit board just needs a clean with some " white spirits "
