Hello all
I got hold of a set of 5 dials from a Y reg hdi 110 since I put them in the fuel gauge doesn’t seem to be working, it was on the second line from the red when I fitted them drove around 100 miles it didn’t move so I put £20 in it then moved to half a tank and stayed there, I’ve put the old 4 dials back in and the has taken about 10 mins to move from the 2nd line to around 1/4 of a tank. Is this a problem with the dials or my car, the oil temp gauge doesn’t work but going to see a nice man from the Peugeot forum on Sunday to enable this and the trip computer.
Any help is appreciated don’t fancy running out of fuel on the motorway
I have a W reg hdi 90
Fuel gauge
- rwb
Re: Fuel gauge
So that's moved from a sixth to a quarter. That's about 8% of the needle's full travel, so not very far at all.hasler88 wrote:taken about 10 mins to move from the 2nd line to around 1/4 of a tank
I'd have said that's within the margin of error of the fuel gauge
For the oil temp there are three places you have to enable it: the instrument cluster, the BSI, and the engine ECU. (The engine ECU will be told that the car doesn't have an oil temperature sensor even though it does.)
Re: Fuel gauge
That was when i put the old dials back in, the new dials is still stuck on half
Sent from my Lumia 920 using Tapatalk
