headlight fault
headlight fault
Wonder if anyone can help me my passenger headlight has gone out and won't come back on but full beam and sidelights are ok and work fine. all fuses look ok too unless there is a fuse box I have missed I've looked in the under bonnet one and under steering column look fine hope someone can help me out
Re: headlight fault
Engine fusebox, F9, 10, 11 & 12. I think you want F9 for left hand dip.
Re: headlight fault
Try another bulb
Re: headlight fault
Are you changing the right bulb, the one thats hard to reach by the ECU box..?
Sorry, you're a clever man but its a silly mistake we often make....
Re: headlight fault
I had a similar problem with mine, couldn't find the cause so fitted a relay energised by the other light.
