Recommend a Contact Cleaner
Can anyone recommend an Electrical contact cleaner spray?
I've got a two-pin plug on the Volvo that connects to the external temperature sensor, I say "connects" and someone recommended squirting the bastard with contact cleaner. I've spotted some WD-40 stuff that says it's non-conducting and dries quick but is that what you do? just squirt both halves of the connector and jobs a good'un?
BTW my car thinks it's +2deg C today and leaves the Climate Control in a right two-and-eight especially with the sunlight and the cabin being as hot as a Sauna.
Re: Recommend a Contact Cleaner
If the contact is quite chunky and/or not high current I'd just file both sides with a fine file or some wet & dry. You only need to get rid of the surface corrosion (which is non-conducting).
For finer connections / if you need high current and want good surface planarity / the connection is actually dirty (rather than corroded), Maplin & the like do a cheap spray can of switch cleaner which will do the job:
http://www.maplin.co.uk/p/maplin-switch ... 00ml-n62an
It's a bit of a twat to get access to this connector, I can just unplug it and just about turn it to face me, that's why I thought a squirty-can might cover the job. I can't see me getting both my hands in there with these filing instruments of which you speak. Even though I happen to have inherited a rather nifty set of said filing instruments. Incidentally am I not at risk of shorting something out if I did poke about with a metal file?
Ah I see, in which case if you can apply a bit of switch cleaner and then plug/unplug the connector a few times that's going to be a good starting point.
Since the connector is two pin, the sensor is likely to be a thermistor, which is just a resistive element. With the connector disconnected, shorting across the sensor side of the connector will cause no problems. Shorting the vehicle side of the connector shouldn't cause any problems since the input stage to the microcontroller (or whatever) will be high impedance. However, for peace of mind, might as well disconnect the battery first.
Don't spray too much on and give it a few minutes to evaporate before applying power again, just to be on the extra safe side.
Do you know that it's the connector that's at fault rather than the sensor itself?
- Site Admin & Mad Biker!
Like Jon says I reckon the sensor has gone fut, my V40 read about 20c over until I changed the sensor.
Regarding terminals, you should be careful with wet and dry on contacts as they are often plated with a protective layer and removal of this will leave the cheaper metal below to deteriorate quicker. Get some Servisol Super 10, however WD-40 is not the demon people make out for electrical contacts!
I found that WD40 works better than a proprietary switch cleaner, at least it did on radio and TV volume controls. I used this in preference to anything else before I retired as a TV engineer. The only problem is that it dries out almost completely so leaves no lubricant, so on switches a small amount of light oil applied afterwards could improve things, 3 in 1 or similar would suit.
The sensor is not faulty, there's been a lot of talk on the Volvo Forum (barring the arguments) where folk have changed the sensor, spliced-in wires, heat-shrink, removing door cards and the like only to find it was the contacts in the connector. All the door wiring plugs in at at the A-pillar, I've actually got the early manufactured version "A" which is best. After a while they "improved" the wiring to version "B" which is sh*t in every department, something Ford suggested apparently, but that guy took early redundancy and now lives in Anglesey with two dogs.
- DaiRees
- Site Admin
I think you'll find that it's only one dog, plus some sheep. There's a goldfish too but I hardly think that counts. Really, you should get your facts straight before you make such ludicrous statements!!!Welly wrote:The sensor is not faulty, there's been a lot of talk on the Volvo Forum (barring the arguments) where folk have changed the sensor, spliced-in wires, heat-shrink, removing door cards and the like only to find it was the contacts in the connector. All the door wiring plugs in at at the A-pillar, I've actually got the early manufactured version "A" which is best. After a while they "improved" the wiring to version "B" which is sh*t in every department, something Ford suggested apparently, but that guy took early redundancy and now lives in Anglesey with two dogs.
Ooops, sorry, slipped into Volvo forums mode for a second there...
Carry on.
- Bailes1992
I use either naplins own brand contact cleaner or WD40 just brought out a contact cleaner which is sh*t hot!
I am asking for advice on a product I DO NOT need your pointless drivel taking up my valuable time, further more....oh hang on
As you were
As you were
- DaiRees
- Site Admin
I think you were rather harsh there Welly, Sam was only trying to help!
- DaiRees
- Site Admin
By the way, I've got an aerosol can of RS Contact Cleaner, it was liberated from an unnamed educational establishment (not by me I might add, I ain't no tea-leaf!) about 20 years ago. Still does the job.
The Radiospares stuff we used to have in the '50s was pretty well neat carbon tetrachloride - outlawed now I believe but it worked well though.
Now, play nicely everyone.
