2.1 diesel cooling fan
hirschhs
Post by hirschhs »
I know there's another thread on this at the moment but as they are different models, I imagine the solution may also be different...
Here's the problem: no a/c on, no engine cooling and it overheats. A/c on and there's some cooling but can still go to 100.
Unplug the right hand plug to the left of the air filter, a/c doesn't work at all but the engine fan is always on.
I'm think relay or some weird electrical connection gone wrong.
Am I right in thinking that the a/c (which works well) has a fan on its own rad and the main rad has another fan?
thanks in advance!
______________
steve h
'97 svdt break
Re: 2.1 diesel cooling fan
The two fans should run simultaneously, I think low speed for a/c and high for cooling (unless one fan is burgered in which case the remaining one will pulse on and off at full speed if you have a/c on). Not 100% on this as it's a long time since I had one but 100% on running simultaneously. The relays are under a cover behind the grille.
rwb
Post by rwb »
I can't remember what all the combinations of slow/fast one/both are... but agreed this definitely sounds like a relay problem.
hirschhs
Post by hirschhs »
right.. sounds likely then.
Grill off to get to relays?
______________
steve h
'97 svdt break
