bought the wrong indicator stalk!
gray
Post by gray »
what can i do?
i bought the indicator stalk with only the rear fogs and not both!
since i don't have rear fogs, is there anyway to make this work with my front fogs?
uuggh :(
Gray
2000 D9 2.0 litre RFV saloon
Re: bought the wrong indicator stalk!
Oops! Where did you get it from?
gray wrote:since i don't have rear fogs
Are you quite sure about that? I thought front fogs were optional but rears were universally obligatory.
gray wrote:is there anyway to make this work with my front fogs?
Well, I guess so. It's not mux so you could probably move the pin to the relevant place in the connector.
gumby6371
Post by gumby6371 »
+1 on rears being a legal requirement and fronts optional, I thought the only choice was whether you get 1 or 2 at the back?
gray
Post by gray »
steve_earwig wrote:Oops! Where did you get it from?
Ebay months ago when i was in canada, cant return them now. My bad!
steve_earwig wrote:Well, I guess so. It's not mux so you could probably move the pin to the relevant place in the connector.
As being Canadian, obviously i have no clue what rear fogs are then! I am in the Dominican Republic there is no fog here! Front fogs are just cosmetic
Anybody know the relevant pin in the connector?
Gray
Gray
Ah, I get it, I'd still expect the lenses to be there, even if they're not wired up. Sadly, being a semi-skimmed the diagrams aren't all that. All I can tell you is you'll have to move it from pin 1B to pin 4B, I know that's not much help but I wouldn't trust a pin-put anyway. The connector is only 9-way so it shouldn't take long to figure out with a meter.
2670+2675 are the fronts, 2630 is the rear.
gray
Post by gray »
Thanks steve i will look into it today
Gray
Gray
gumby6371
Post by gumby6371 »
Mr Google says - Rear fogs have been a legal requirement on all new vehicles since 1986, if only 1 is fitted it must be on the offside or centre of the vehicle.
Assuming the majority of 406's were left hookers and assuming the law applies to the majority of countries it was exported to I suspect they're there but possibly not working.
Personally I'd be tempted to plug the new stalk in and see what happens, maybe pop the off side bulbs out and have a look how many bulbs you have.
My D8 had bulb slots both sides but only the off side wired up, presumably so the same parts fitted all models and only the loom changed.
gray
Post by gray »
So what is rear fog?Image
And with parking lights on
As you noticed and as this is the first time i have opened this someone has jumpered this light have to find out why?
Sent from my iPhone using Tapatalk
Gray
gumby6371
Post by gumby6371 »
As my memory is pretty poor I always end up turning the lights on in sequence to work out which bulb is which, I'd detatch that wire first of all and see what's still working.
Not sure what you mean by parking lights but having 3 bulbs lit seems a bit odd if it's just side lights and the one in the bottom of shot is suspiciously bright.
Is your car a left or right hand drive?
gray
Post by gray »
Aha found out what rear fogs are
"Rear fog lamp- a red light with the same intensity as a brake light."
Ya, north america do not have them!
That explains my extra bright bulb!
Gray
Gray
gray
Post by gray »
As you can see even the internals are different the wires are soldered onto diff pins
For that reason when i put the headlights on with out the rear fogs rear fogs come on.
Anyone know how i can eliminate the rears and use as front fogs? Not much of electrician but i have a multimeter now
Gray
gray
Post by gray »
Fixed it by moving the pin outs
Gray
