Bit of a random one- my side lights come on when I brake, then turn off when I release the brake pedal.
At the moment the third brake light is not working (fuse is fine, not got around to digging any further)- could it be Peugeots way of telling me there is a problem? or do I have a wiring gremlin which is causing it?
Side lights come on when braking
2002 406 HDi 90 Rapier Estate
2001 206 1.6 GLX
2001 206 1.6 GLX
Re: Side lights come on when braking
Take the bulbs out one by one and see if the problem is solved with any particular bulb removed.
You may have a bulb in wrong way round or the wrong bulb fitted.
Bad earth conenction on rear bulb holers
